- Alon/M10 Specific
- M10 GASCOLATOR GASKETS
- Scott Engelhart
30 Sep 2017 13:37 #1
by Scott Engelhart
Replied by Scott Engelhart on topic M10 GASCOLATOR GASKETS
Gordie,
Thanks again for chiming in. Latest Spruce catalog, page 447 GASCOLATOR GASKETS, lists 2" 21/8" and 21/4" o rings and the 2 1/4" are offered in 1/16 and 1/8 thickness as you mention. My plane is in my A&P's locked hanger so I cant measure. Guess I'll order a few things from Spruce including 2 of the 2 1/4" x 1/16 thick O rings.
- Gordie Meade
30 Sep 2017 12:11 #2
by Gordie Meade
Replied by Gordie Meade on topic M10 GASCOLATOR GASKETS
I am doing this from memory since I'm at home. There are two gaskets, a top and bottom that seal the glass tube. As I recall they are 3 inch diameter by 1/16 inch thick. Pull the bottom off the gascolator and measure the diameter. I think it is 3 inches but it's been a while since I did it. Index in Spruce catalog puts you on the correct page. There are 1/16 thick and 1/8 thick. Get the 1/16 as the 1/8 will not allow the glass tube to seat correctly.
- Scott Engelhart
30 Sep 2017 07:20 #3
by Scott Engelhart
Hi Gordie,
Thanks for the response. What exactly is the "it" you ordered? Maybe a Spruce part #?
Thanks!
Thanks!
- Gordie Meade
29 Sep 2017 18:59 #4
by Gordie Meade
I measured it and ordered it from Spruce. Be sure and get the thinner one as the thick one does not seat correctly.
- Scott Engelhart
29 Sep 2017 18:14 #5
by Scott Engelhart
M10 GASCOLATOR GASKETS was created by Scott Engelhart
My M10 is going through a through Annual. I asked my A&P to open up/inspect the gascolator and he asked me to get any needed gasket(s). My old Skyport catalog is MIA, anyone know what is needed?
Thanks guys,
Scott
Thanks guys,
Scott
Time to create page: 0.180 seconds
