- electrol nose gear
electrol nose gear
09 Dec 2021 16:07 #1
Replied by Warren Hampton on topic electrol nose gear
That second C ring is a bitch to get at .so I feelyour pain!.. I just rebuilt my second Electrol
- William Stilley
20 Sep 2018 18:12 #2
by William Stilley
Replied by William Stilley on topic electrol nose gear
Pins do not have to be removed. Found a sentence on one of the later Fourney maintenance manuals that described removing a second snap ring. Finally found it behind the aluminum rod guide, which at first seemed part of the inner cylinder. Once the rod guide was removed using a dental pick, the second snap ring was accessible. All is well. I got the manual from Essco.
- William Stilley
26 Aug 2018 12:55 - 26 Aug 2018 15:58 #3
by William Stilley
electrol nose gear was created by William Stilley
I need the exact procedure for disassembling an Electrol nose gear strut. How do you remove the pins that seem to hold everything together. It is not described in the Univair manuals.
Last edit: 26 Aug 2018 15:58 by William Stilley. Reason: add pin info
Time to create page: 0.162 seconds
