- nose panel replace
nose panel replace
29 Sep 2019 16:37 #1
Replied by Matt Gunsch on topic nose panel replace
Looks good, now on to the next job......
- Ronald Paxton
28 Sep 2019 17:37 #2
by Ronald Paxton
Replied by Ronald Paxton on topic nose panel replace
the 337 is signed. this job is dun.
- Ronald Paxton
19 Aug 2019 17:15 #3
by Ronald Paxton
four hours of bucking rivets is all i can handle for one day.
- Ronald Paxton
12 Aug 2019 17:02 #4
by Ronald Paxton
thank you for the encouragement.
this picture is just a test fit before i start rivetting. but it feels good to see parts come off the shelf.
and i ordered another left side panel today.
11 Aug 2019 14:26 #5
Looking good, keep at it, some people are naturals at sheet metal, I am not one of them...
- Ronald Paxton
11 Aug 2019 14:15 #6
by Ronald Paxton
i renewed my membership a couple of weeks ago and realized i've been working on this for well over a year and have not been winning. the left side panel ended up with a wrinkle at the upper rear corner. i tried shimming and considered some other ideas. finally i decided the only thing worse than ruining a 500 dollar piece of metal is not admitting it.
so i moved on to the right side. i put a lot more effort into making the panel lay against the frame before drilling any holes and figured out where i went wrong on the left.
the new panel is formed to have a compound curve. the curve in the panel is constant but the shape of the airframe is not. frame "b" curve straightens out toward the bottom. there is no way to avoid having a wrinkle in the panel. so i've forced the wrinkle to the lower rear part of the panel. i hope the wing root fillet can absorb the wrinkle.
Time to create page: 0.170 seconds
