- Ercope 415c sts for gross weight increase to 1320 from the 1260.
- Frederick Melick
04 Sep 2020 21:19 #7
by Frederick Melick
Replied by Frederick Melick on topic Ercope 415c sts for gross weight increase to 1320 from the 1260.
Thank Ron for the information. I guess that is a full span addition to the elevator replacing the existing one. Thanks again .
Fred M
Fred M
04 Sep 2020 01:03 #8
Replied by Ronald Raty on topic Ercope 415c sts for gross weight increase to 1320 from the 1260.
The description of the requirements are here:
alphaaviation.com/ercoupe-1320-gross-weight-increase-stc/
There are no parts to install. You have to have the proper trim tab like on the 415-D's or later models. If you have a trim control on the left side of the cockpit, and the tab is 1-3/8" (not 3/4"), or you have the E-model cut away elevator, then you should be good to go.
The following user(s) said Thank You: Frederick Melick
- Frederick Melick
03 Sep 2020 23:52 #9
by Frederick Melick
Ercope 415c sts for gross weight increase to 1320 from the 1260. was created by Frederick Melick
Hi all:
Does anyone have pictures that they would be willing to share showing the modifications required to install the parts required to meet the STC for the gross weight increase to 1320 from the 1260 gross weight on the Ercoupe 415 C
Thank You
Fred M (New member ) Still looking for a 415C Ercoupe Just an old has been pilot looking to fly just once more under the sport pilot regs.
PS I can be also be reached at my email address This email address is being protected from spambots. You need JavaScript enabled to view it.
Thank You
Time to create page: 0.124 seconds
