- Oil weight
Oil weight
- Morris Pearson
05 Oct 2020 21:02 #1
by Morris Pearson
Replied by Morris Pearson on topic Oil weight
Finally got thru to previous owner and he had been using Phillips XC 20W50 so I will keep using it as well.
- Henry Pasquet
01 Oct 2020 15:20 #2
by Henry Pasquet
Replied by Henry Pasquet on topic Oil weight
When I put new cylinders on my engine, ECI mandated Phillips 20w50 for break in and continued use. It is like 20 when cold and 50 when hot. I have had perfect results for years and do not have to warm up a long time in cold weather.
- Morris Pearson
29 Sep 2020 18:45 #3
by Morris Pearson
Oil weight was created by Morris Pearson
Reading the C85 manual they call for SAE 40 when the temp is 40 or better and SAE 20 below 40. I can find SAE 40 single weight but am striking out on anything below SAE 40. All the multi weight oils seem to be 15W50 or 20W50. So---- what oil are you using when the temps go below 40?
Time to create page: 0.091 seconds
