Com Radio
  • Steve McNew
13 Feb 2017 12:54 #1 by Steve McNew
Replied by Steve McNew on topic Com Radio
Gosh! I had an ancient Narco, which was quite noisy - and I broke a knob from it with my knee, while trying to get under the panel area, to do some work on my heat duct - replaced the now-necro-Narco with a slide in ktm Mx-11; it cost me 475! You guys play in a larger pond than I, I guess!
12 Feb 2017 18:18 #2 by George Sellers
Replied by George Sellers on topic Com Radio
Good to hear that!
12 Feb 2017 13:45 #3 by Bruce Bennett
Replied by Bruce Bennett on topic Com Radio
It is advertised as experimental because it is
not TSO'd. An Ercoupe flown VFR. doesn't
require a TSO'd com (ref Ed Burkhead's Ercoupe
info if needed). Wasn't an issue.
12 Feb 2017 07:33 #4 by George Sellers
Bruce thank you very much for your prompt reply. Did you have any trouble getting an avionics shop to install the Garmin since it is advertised for experimental aircraft?
12 Feb 2017 04:10 #5 by Bruce Bennett
My old ValCom 760 died and my intercom wasn't
far behind. Was going to replace the 760 with their
2000 model when Garmin came out with their GTR 200
which included a built-in intercom. Perfect solution.
Paid a little extra for the prewired option at Aircraft Spruce.
Greatly simplified installation and works well.
11 Feb 2017 18:25 #6 by George Sellers
Com Radio was created by George Sellers
My wife and I have an older Val com radio in our Coupe, and we are thinking about replacing it. We would like to know what are your recommendations for a good replacement.
Thanks--George
Time to create page: 0.166 seconds
