- GPS verification of indicated airspeed spreadsheet program?
14 Nov 2017 12:35 - 14 Nov 2017 12:39 #1286
Larry Snyder replied the topic: GPS verification of indicated airspeed spreadsheet program?
Here is the true speed calculating spreadsheet in OpenOffice format. I can understand not having Excel, since Microsoft charges a lot for it, but OpenOffice is free! If you want to use this spreadsheet and don't have OpenOffice, just google it and download it!
Last Edit: 14 Nov 2017 12:39 by Larry Snyder. Reason: Adding attachment
02 Nov 2017 10:07 #1279
Yeah, I double checked and found the 4-year requirement. No problem. I just do it, fill out the spreadsheet, and then print it out and sign and date it, and then store it in my logbook folder. I just show it to the IA doing my annual and he logs that all ADs are C/W.
This is really annoying! Now we have ADs required every 100 hours, every annual, every 3 years, and every 4 years. It is getting increasingly difficult to stay legal!
- Bud Bornemann
12 Oct 2017 11:56 #1247
by Bud Bornemann
Bud Bornemann replied the topic: GPS verification of indicated airspeed spreadsheet program?
Larry. Di not have Microsoft Office so can not open your file.
10 Oct 2017 00:47 - 10 Oct 2017 00:55 #1242
Edward Moore replied the topic: GPS verification of indicated airspeed spreadsheet program?
Larry:
I just completed a detailed experience I had with the FAA ACO re AC23-8C, etc but I apparently took too long and it failed to transmit to you/page.
I'll just be succinct and suggest you check AD2012-18-06 (g) paragraph 8 viz-a-viz your "one time requirement", respectfully.
Last Edit: 10 Oct 2017 00:55 by Edward Moore.
09 Oct 2017 10:05 #1239
On that spreadsheet, you fly in three directions 120 degrees apart and record the ground speed from the GPS in each direction. You enter the numbers in the top 6 cells. There are three sheets in the workbook, for three different speeds.
09 Oct 2017 10:03 #1238
I am attaching an Excel spreadsheet that implements that program. I used it to pass the one-time airspeed regulation as part o the aileron/airspeed AD that came out a few years ago.
Larry
Larry
