- Alon/M10 Specific
- CANOPY LATCHES
CANOPY LATCHES
- Henry Pasquet
11 Feb 2021 13:59 #1
by Henry Pasquet
Replied by Henry Pasquet on topic CANOPY LATCHES
Check my "Snap vents" subject. I lost too much climb and cruise with the canopy unlatched. The snap vents were the solution.
- Gordie Meade
10 Feb 2021 20:15 #2
by Gordie Meade
Replied by Gordie Meade on topic CANOPY LATCHES
I have had them pop open multiple times, usually as I apply power to take off. With the canopy unlatched but closed, I get MUCH more cooling air in the summer but lose about 4-5 mph in cruise.
- Scott Engelhart
24 Jan 2021 13:14 #3
by Scott Engelhart
CANOPY LATCHES was created by Scott Engelhart
I have never cared for the canopy latches on my 1970 M10, they consist of a little threaded rod with a "catch" at the end. It needs to be adjusted just so or it wii not draw up tight, or if too tight will pop in flight.Of course the right side is the most finicky. I believe I saw an Alon once that had a different style latch, with a single metal strap, not ulike a lunch box latch. Any of you M10 guys dealt with this also? Wondering if there was more than one style latch? Any comments most welcome.
Time to create page: 0.093 seconds
