- Starting Battery Booster
- Ken Thompson
07 Apr 2023 15:36 #1
by Ken Thompson
Replied by Ken Thompson on topic Starting Battery Booster
I have a pigtail cable that connects to my battery terminals, comes up through the baggage floor and is mounted horizontally on the baggage wall behind the passenger seat. It is easily connected to a Battery Minder/charger/starter.
19 Mar 2023 02:02 #2
Replied by Warren Hampton on topic Starting Battery Booster
You want to externally plug to your car or any outside booster, right? Both Piper and Cessna have plug to do so. Go to Aircraft Spruce they have them!
03 Mar 2023 19:51 #3
Replied by Ronald Raty on topic Starting Battery Booster
I would so love to do that, rather than pulling everything out of the baggage compartment, then the cover off the battery case.
I have thought about pulling all the fuses, turning on the master, and connecting at the starter motor.
- Lynn Kramer
03 Mar 2023 18:34 #4
by Lynn Kramer
Starting Battery Booster was created by Lynn Kramer
I am looking to install an engine starting battery charging hook up. Do you know of such a thing? I would like to be able to clip a starter booster to the master relay without having to remove the floor panel to access the battery. Any suggestions?
Time to create page: 0.137 seconds
