- Can anyone identify these holes?
- Greg Harris
27 Jun 2023 20:27 #1
by Greg Harris
Replied by Greg Harris on topic Can anyone identify these holes?
Good. Just making sure
Thanks!
Thanks!
27 Jun 2023 16:57 #2
Replied by Matt Gunsch on topic Can anyone identify these holes?
Those are jigging holes, when the part is made, a bolt passes thru the hole and holds the metal to the die or form.
- Greg Harris
26 Jun 2023 21:30 #3
by Greg Harris
Can anyone identify these holes? was created by Greg Harris
If you haven’t seen my other posts, I am bringing “Erkel” back to life after a 10 year nap outside under a tree…
Gene helped me move it and remove the wings. I got a horoscope and started looking around for corrosion. On both the right and left side what I think is the center spar has two drill holes that have no apparent purpose. They are empty. One does not look good, but it may just be muck. I still need to try and clean up before looking for corrosion.
see the attached pictures. Two are the front side and backside of inside the left wing walkway, and the other are the right.
Can anyone tell me what these are?
Also, you can see my progress at myercoupe.com. I’m going to post some of these pictures.
Time to create page: 0.122 seconds
