- Main Wheel Shimmy
Main Wheel Shimmy
20 Nov 2023 20:51 #1
Replied by Matt Gunsch on topic Main Wheel Shimmy
if you are looking for a measurement, there is none that I am aware of. You can try to tighten the nuts on the knee joint and see if that takes up the slack, if not, pull the shaft and inspect it and the bushings, A little side to side would probably be acceptable, one thing to remember, that the center of the axle to the center of the knee is a long lever arm, and a little movement at the knee will show up as a lot of movement at the axle.
The following user(s) said Thank You: John Duncan
- John Duncan
20 Nov 2023 12:25 #2
by John Duncan
Replied by John Duncan on topic Main Wheel Shimmy
I’m doing my first annual on a 415 c/d. In your answer, do you mean there should not be any lateral movement of the lower leg at the knee? Mine has some lateral play and I’m looking for how much is to much.
Thanks
Thanks
- David Gilson
28 Jul 2023 18:25 #3
by David Gilson
Replied by David Gilson on topic Main Wheel Shimmy
I haven't checked anything yet, I will start there, thanks.
28 Jul 2023 15:18 #4
Have you checked the clips that center the disc ?
- David Gilson
27 Jul 2023 21:36 #5
by David Gilson
Along the same lines, I have goodyear brakes and when I'm taxiing and apply the breaks there is a very noticeable shutter that vibrates through the whole plane. Any thoughts?
24 Jul 2023 19:29 #6
all you can do is go thru the gear and make sure none of the bushings are worn out, check the wheel bearings and gear mounting bolts. The reason you do not hear of main gear shimmy is a shimmy is a left right action, and the main gear is by design, up and down movement, There should be no left or right movement on the mains.
Time to create page: 0.139 seconds
