- Carb heat
Carb heat
- Greg Harris
09 Dec 2023 13:17 #1
by Greg Harris
Replied by Greg Harris on topic Carb heat
Yea, I realized that after I posted question.
Thanks!
Thanks!
09 Dec 2023 10:27 #2
Replied by Matt Gunsch on topic Carb heat
the auto carb heat is on the air box,
08 Dec 2023 02:44 #3
Replied by Larry Snyder on topic Carb heat
Sorry but I can’t really see on the picture. Basically, any other connection to the carb heat flapper than the carb heat control would be auto carb heat.
- Greg Harris
07 Dec 2023 23:45 #4
by Greg Harris
Does this mean I don’t have the auto carb-heat? Is this where the bracket would be? See attachment.
Just curious what it looks like if hasn’t been removed.
28 Jul 2023 18:59 #5
The auto setup lets you manually carb heat any time you want.
- David Gilson
28 Jul 2023 18:27 #6
by David Gilson
Replied by David Gilson on topic Carb heat
I will check this weekend. Thanks for the info. If it is still installed I figured I would disconnect it also because I'm used to applying carb heat below the green line.
Time to create page: 0.145 seconds
