- Engine Overhaul
Engine Overhaul
19 Dec 2023 22:54 #1
Replied by Warren Hampton on topic Engine Overhaul
Larry can you send your spec sheet. and what happened with front wheel part?
19 Dec 2023 22:31 - 19 Dec 2023 22:49 #2
Not really sure why you are looking for O/.H pricing if Bottom end passes inspection. Sound like you are asking about top O/H.?? To fully O/H the engine some where around $12,000. Top buy used Jugs and have them O/H Willie Topken has a set he was telling me he want to sell. 775-338-5717 or This email address is being protected from spambots. You need JavaScript enabled to view it. That way you can keep flying until you are ready to do the top...
Last edit: 19 Dec 2023 22:49 by Warren Hampton. Reason: more to say and spelling with extra letter.
19 Dec 2023 19:06 #3
Replied by Larry Snyder on topic Engine Overhaul
Here's the spec. Maximum allowable oil burn is 0.4 quart per hour, so I guess that works out to a quart every 2.5 hours.
- John Farrell
19 Dec 2023 17:33 #4
by John Farrell
Replied by John Farrell on topic Engine Overhaul
Yep. . .12F. So what's the cost of O/H if bottom passes inspection?
19 Dec 2023 01:51 #5
Hope you meant C85-12F! Your number look good. But you have an airplane start saving...
18 Dec 2023 17:32 #6
According to Continental, the maximum allowable oil consumption rate is a quart every 2.8 hours. If I can find it, I’ll post the bulletin in this thread. My C85 has 1600+ hours on it and uses a quart every 10-12 hours. It could be your burning oil in the jugs. How are your compressions?
Time to create page: 0.191 seconds
