- Loss of power at high angle of attack
03 Dec 2018 13:14 #1
Replied by Matt Gunsch on topic Loss of power at high angle of attack
I noticed that this thread started in July, an issue I have with some of my flight school planes in summer heat is vapor lock. With the running of auto gas and the high temps, you might have been on the edge of vapor lock and when at high angles of attack the fuel was fighting bubbles to get to the carb.
The following user(s) said Thank You: Dean Weichmann
- Dean Weichmann
02 Dec 2018 17:01 #2
by Dean Weichmann
Replied by Dean Weichmann on topic Loss of power at high angle of attack
No issues other than hesitation on opening the throttle to fast. This may be just characteristic of the carb, no accelerator pump. I may have the carb overhauled once winter sets in and I choose to park the Coupe for a while. Right now having fun with it and earning my sport pilot license.
- Ken Thompson
07 Nov 2018 16:22 #3
by Ken Thompson
Replied by Ken Thompson on topic Loss of power at high angle of attack
Dean, any recurring issues with this fuel problem? Or has is resolved itself?
- Dean Weichmann
17 Jul 2018 21:08 #4
by Dean Weichmann
Second flight went very well. Cooler, perhaps more avgas. No problem at high angle of attack this time.
- Dean Weichmann
16 Jul 2018 15:25 #5
by Dean Weichmann
Thanks Henry, I am scheduled to go tomorrow....I am comfortable with a takeoff at a low angle of attack, I believe the CFI is as well. We will discuss it. I will have the carb checked. Gas flow is unimpeded at the gascolator.
- Henry Pasquet
16 Jul 2018 12:05 - 16 Jul 2018 12:07 #6
by Henry Pasquet
Replied by Henry Pasquet on topic Loss of power at high angle of attack
I would check the gascolator and disconnect the fuel line from the carb and see if you get a good flow of gas into a container. Avgas is much better than auto. It may need a carb overhaul. Check the float level in the carb. I would fix it before the next flight.
Last edit: 16 Jul 2018 12:07 by Henry Pasquet.
