- How Elevate Ercoupe to Change Tires
11 Aug 2021 19:09 #7
Replied by Matt Gunsch on topic How to Elevate Ercoupe to Change Tires
See the post above yours, for the mains you insert a steel rod thru the knee and use that as your jack point.
- Tim Cowden
11 Aug 2021 17:54 #8
by Tim Cowden
Replied by Tim Cowden on topic How to Elevate Ercoupe to Change Tires
I just bought a 1946 415-C. Is it correct to say that there are no hardpoints on the aircraft to allow you to properly jack it up? Other aircraft I have owned had hardpoints under the wings for this purpose.
Tim
Tim
15 May 2021 23:42 #9
Replied by Matt Gunsch on topic How Elevate Ercoupe to Change Tires
It is covered in the service manual, for the mains you can put a steel rod thru the main gear pivot and lift with a jack. For the nose you can place bags of sand on the horizontal and weigh the tail down.
- Robert James
15 May 2021 22:04 - 15 May 2021 23:22 #10
by Robert James
How Elevate Ercoupe to Change Tires was created by Robert James
Last edit: 15 May 2021 23:22 by Robert James. Reason: Adding pic
Time to create page: 0.147 seconds
