- Leaky C85 Oil Sump Drain - Fix?
23 Aug 2021 19:49 #1
Replied by Matt Gunsch on topic Leaky C85 Oil Sump Drain - Fix?
most of the drains use a odd ball sized O-ring, better to replace the drain.
The following user(s) said Thank You: Brady Buttterfield
- Brady Buttterfield
23 Aug 2021 15:28 - 23 Aug 2021 17:51 #2
by Brady Buttterfield
Leaky C85 Oil Sump Drain - Fix? was created by Brady Buttterfield
Now that I'm getting familiar with the old girl, I'm working on a few issues. The majority of my after-flight oil leaks seem to be coming from a leaky oil drain. It makes a bit of a mess as there is a good amount of oil that drips down the nose gear onto the tire. I was planning on doing my first oil change soon and I hope to fix the issue. Should I replace with new/old stock such as
this
? Or should I just stretch the spring a bit or replace o-rings? Is there a better solution replacement part?
Last edit: 23 Aug 2021 17:51 by Brady Buttterfield.
Time to create page: 0.186 seconds
