- Remove Vacuum and add AV-30
26 Oct 2023 13:07 #7
Replied by Warren Hampton on topic Remove Vacuum and add AV-30
Was it installed under a 337? If so, can I get your N-number so I can get a copy of that 337. offsite This email address is being protected from spambots. You need JavaScript enabled to view it.
26 Oct 2023 13:00 #8
Replied by Larry Snyder on topic Remove Vacuum and add AV-30
I was looking at altimeters and the TSO’d versions were nearly $1,000 more!
- Greg Harris
- Away
26 Oct 2023 11:18 #9
by Greg Harris
Replied by Greg Harris on topic Remove Vacuum and add AV-30
46 Ercoupe 415-C
25 Oct 2023 23:33 #10
Is your Coupe an Ercoupe, Forney, Alon or M10
? It has a C90-16f to have a Vac system. I ask because I am looking for paperwork for C90-16F in a 415e airframe.
- Greg Harris
- Away
25 Oct 2023 15:52 #11
by Greg Harris
Thanks.
I was thinking to be safe I should get the TSO'd versions. They are a little more expensive but not much.
I would be leaving all the gauges you mentioned.
Hard part is going to be able to find an A&P who will inspect and sign off. I'd like to find someone in the Philadephia / New Jersey area who knows enough about Ercoupes to work with me as well as do my annuals, etc.
Thanks for your input!
- Super User
25 Oct 2023 15:17 #12
by Super User
Replied by Super User on topic Remove Vacuum and add AV-30
You can do the work, but will need an A&P to "oversee" your work and sign it off.
The following user(s) said Thank You: Greg Harris
Time to create page: 0.144 seconds
