- Tie Down recommendation
12 Feb 2024 12:13 #1
Replied by Larry Snyder on topic Tie Down recommendation
If you use the reply option from the actions menu, underneath the box where you enter the text there is an attachments button. You can click on that to append pictures. Hopefully that helps!
- Tim Cowden
12 Feb 2024 12:04 #2
by Tim Cowden
Replied by Tim Cowden on topic Tie Down recommendation
Larry,
As ususal you are a fountain of knowlege. What is the procedure to attach photos to the forum?
Tim
Tim
22 Dec 2023 07:31 #3
I got those hooks at the hardware store. They are NOT the aluminum carabiners that you often see. They are steel and actually have little overlapping hooks that prevent it from opening under stress.
Tying down is easier with these. Just clip one end on the ring on the plane and the other end cable or tie down ring and pull it tight. I’ve been at a couple of airports that had rings too big for my clips, so made a loop in the rope and hooked on to that. On another airport I slid it under the embedded ring and hooked it to itself.
Hope you get lots of opportunities to use the straps!
- Bob DeMunck
21 Dec 2023 14:11 #4
by Bob DeMunck
Replied by Bob DeMunck on topic Tie Down recommendation
Thanks Larry! This is most helpful. I'll give a try.
19 Dec 2023 19:16 #5
- Bob DeMunck
16 Dec 2023 15:36 #6
by Bob DeMunck
Larry, can you post a picture of those hooks/clips?
Also, is there any certain strength that those hooks need to be rated at?
Thanks,
Bob
Thanks,
Bob
