- fuel flow between wing tanks
- Ken Thompson
23 Jun 2019 10:47 #1
by Ken Thompson
Replied by Ken Thompson on topic fuel flow between wing tanks
Steve, I had this issue when I first got my plane.
I finally blew out my gas caps vents with compressed air. That did the trick. Must have been a bug or something up in there so it was not properly venting.
I’ve also read that a bad cap gasket can cause a venting problem, as well as having a cap that is way too tight.
- Steve McNew
20 May 2019 12:35 #2
by Steve McNew
fuel flow between wing tanks was created by Steve McNew
Just a question - my coupe is lower on fuel on the R side, every time I gas up. The connecting line was blown out, finding no blockage, last month. Does anyone else have that situation? Do I fly with the left side lower? The tanks are even after we've sat a while. Thanks, Steve
