- Elevator Cable Tension
27 May 2022 20:16 #1
Replied by Matt Gunsch on topic Elevator Cable Tension
they are going to the same point, the tension should be the same on both cables. make sure you check the tension with the elevator in neutral.
The following user(s) said Thank You: Lyle Motley
- Lyle Motley
27 May 2022 19:38 #2
by Lyle Motley
Elevator Cable Tension was created by Lyle Motley
Regarding the elevator cable tension, is there a maximum allowable differential in the cable tension? Or, by design, is it okey as long as each cable is within spec….. Thanks, Lcm
Time to create page: 0.126 seconds
