- Dimmer on Nav Lights?
- Greg Harris
- Away
11 Dec 2023 23:26 #1
by Greg Harris
Replied by Greg Harris on topic Dimmer on Nav Lights?
That’s what I was thinking. No idea why someone would think it’s ok to dim the nav lights.
Thx for your feedback.
11 Dec 2023 18:37 - 11 Dec 2023 19:40 #2
Replied by Matt Gunsch on topic Dimmer on Nav Lights?
sounds like what they did was to tap into the nav light circuit to power the instrument lights, if the rheostat is bad, it could be causing a short. The nav light should never be dimmed, if they do, they no longer meet the specs for external light.
Last edit: 11 Dec 2023 19:40 by Matt Gunsch.
- Greg Harris
- Away
07 Dec 2023 23:22 #3
by Greg Harris
Dimmer on Nav Lights? was created by Greg Harris
Hey all,
Would there be a valid reason to have a dimmer on the nav lights? I recently purchased my Ercoupe and the nav light circuit breaker keeps tripping. The previous owner covered the switch as inoperable until I fix it.
I noticed this rotary knob on the das, and it’s connected to the Nav light switch.
There can’t be a valid reason for this, right? I can see dimming interior lights or instrument lighting, but the nav lights?
You can see from the photos that is is connected to the nav lights.
Time to create page: 0.125 seconds
