- Classifieds
- Wanted
- 30 Gallon Stc
30 Gallon Stc
- William James
21 Nov 2018 13:22 #7
by William James
Replied by William James on topic 30 Gallon Stc
Michael
I have the 30 gal tanks on my coupe. Makes it a passable cross country aircraft . . . fuel out lasts my bladder capacity. Gives a legit 5 hour + range. I have the long pill mixture cable so I can lean down to under 5 gal per hour. Call Mike Widowsky @ 440 785 2263 (Ohio)
He did the tanks on my plane and probably could steer you to your needs. I have read the STC procedure and I would guess the cost to make the change would be a ball buster today. One especially important factor to me was the removal of the header tank opened room behind the panel for needed IFR instruments . Call me if I can help.
Bill James
330 495 6041
Bill James
330 495 6041
The following user(s) said Thank You: Michael Hensley
- Michael Hensley
19 Nov 2018 15:06 #8
by Michael Hensley
30 Gallon Stc was created by Michael Hensley
I'd like to get a copy of the 30 gallon stc that used to be available through Skyport Services. Please reply to This email address is being protected from spambots. You need JavaScript enabled to view it.. Thanks, Mike.
Time to create page: 0.157 seconds
