- Classifieds
- Wanted
- looking for any data of a C90-16F installed in 415D
- Bill Harpole
15 Aug 2023 07:54 #1
by Bill Harpole
Replied by Bill Harpole on topic looking for any data of a C90-16F installed in 415D
Hi Warren, nothing has changed yet. I am still working on the paperwork side of things. I agree it should have been a simple process of a 337 and WB. Years ago it would have been but the feds don't do much field approval now.
I finally talked enough about it withimy local rep and he is walking the whole thing through now. So should have a final answer within a couple months.
14 Aug 2023 22:21 #2
Replied by Warren Hampton on topic looking for any data of a C90-16F installed in 415D
What has been happening? I find this type of thing and ongoing type of problem. And people not letting us know the outcome.
04 Aug 2023 23:55 #3
Replied by Matt Gunsch on topic looking for any data of a C90-16F installed in 415D
when they installed the C90 in my G model, it was a single line item on the 337 for rebuilding the plane, If it registared as a D model, then you should be able to show to the FAA that it is on the same TCDS that has that engine installed in later models.
- Bill Harpole
17 Jul 2023 09:28 #4
by Bill Harpole
I have gone through the process of having cases reline bored before, As for installing the -16F with a 337 my local FSDO will NOT do a field approval with out me coming up with some already approved install of a -16F. I even tried showing them that a -16F is the same case used for the O-200 and there is and STC for but no go.
16 Jul 2023 15:07 - 16 Jul 2023 15:12 #5
Cases don't mix w/o being reworked to be sure no miss a lineament. Only diff between 12F and 16F is the vacuums pump and a few pounds. so, a 337 and new Weight and Bal should fix you up...
Last edit: 16 Jul 2023 15:12 by Warren Hampton.
- Bill Harpole
13 Jul 2023 15:31 #6
by Bill Harpole
looking for any data of a C90-16F installed in 415D was created by Bill Harpole
I have a C90-16F that I am looking to install in a 415D, currently have a C90-12F installed with a bad case. Or need a good half case for a c90-12f
Time to create page: 0.140 seconds
