- Classifieds
- Wanted
- Oil Dip Stick
Oil Dip Stick
- John Farrell
11 Dec 2020 12:48 #1
by John Farrell
Replied by John Farrell on topic Oil Dip Stick
As Larry said "easy peasy" even for a novice like me when it comes to mechanical issues! Tighter fit now.
04 Dec 2020 21:55 #2
Replied by Matt Gunsch on topic Oil Dip Stick
the cap is easy to take apart, just push and twist,
The following user(s) said Thank You: John Farrell
- John Farrell
02 Dec 2020 18:18 #3
by John Farrell
thanks for that suggestion, Larry
02 Dec 2020 17:36 - 02 Dec 2020 17:37 #4
Replied by Larry Snyder on topic Oil Dip Stick
You probably don’t need a new one. Easy peasy:
1. Buy a new silicon gasket at www.realgaskets.com. It might make it tight enough to seal. But if it doesn’t:
2. Tap on the tangs in the cap to tighten the seal. Don’t overdo it, those silicon gaskets don’t need a ton of pressure to seal.
Fixed!
Fixed!
Last edit: 02 Dec 2020 17:37 by Larry Snyder.
- John Farrell
02 Dec 2020 17:00 #5
by John Farrell
Oil Dip Stick was created by John Farrell
Looking to replace my oil dip stick for a C-85 engine. Mine does not close tightly. Probably the original one. My coupe is a 1948 415E hot rod. N94865. Only had it three months. Old Bonanza driver. My last Hoorah! Fun to fly! Thanks
