- header tank leak
header tank leak
29 Feb 2024 15:36 #13
Replied by Larry Snyder on topic header tank leak
If you try to replace a 5 gallon tank with a 6 gallon tank the filler necks are in different places. I’m amazed an A&P would R&R a header tank for $1000!!
- Kenneth Crofut
29 Feb 2024 15:34 #14
by Kenneth Crofut
Replied by Kenneth Crofut on topic header tank leak
Talk with your A&P. Mine pulled the header tank, cleaned it, pressure tested and solder fixed three leaks then reinstalled. Total price $1000. He said a new tank created or store bought would result in top cowling where neck goes through not lining up.
29 Feb 2024 06:04 #15
No amount of sealer will work for very long. JB Weld isn’t legal. Hate to say it, but the only real solution is pulling the tank and probably repairing/replacing it.
There are places that will build a new tank and use your old filler neck so it’s a “repair”.
Every time I’ve tried putting sealer on a leak it didn’t last very long.
- Jerry Nograsek
29 Feb 2024 05:52 #16
by Jerry Nograsek
Replied by Jerry Nograsek on topic header tank leak
Well first I would clean up the entire area and understand where the leak is originating. I would also see if that “fuel valve” is an aircraft part. Looks kind of “Ace hardware”. JB Weld wouldn’t be on my list of repair options
- Nathan Bissonette
28 Feb 2024 17:01 #17
by Nathan Bissonette
header tank leak was created by Nathan Bissonette
