- header tank leak
header tank leak
21 Apr 2024 13:47 #7
Replied by Ronald Raty on topic header tank leak
If you can pressurize the tank with a low pressure (I use a balloon as a pressure regulator), then use soapy water to identify exactly where the leak is at. Then, if you can get a small low pressure (vacuum) in the tank (not too much, don't collapse the tank), you could maybe paint a sealant over the leaky seam and suck it back into the leak to seal it. Just a thought.
21 Apr 2024 11:41 #8
Replied by Larry Snyder on topic header tank leak
Forgot to mention- if your tank is riveted, then the Univair tank won’t fit. It’s a welded aluminum tank, 6 gallons. Riveted tanks are 5 gallon. The filler is in a different place too.
21 Apr 2024 11:37 #9
You are certainly asking for BAD advice!
You can slosh your tank and it will last until it doesn’t any more and you’ll find yourself trying to handle a glider with a 5:1 glide ratio.
I don’t see how can really do any fix on it without taking it out and putting it back in, which is a big chunk of the cost.
IMHO sloshing it will put off the inevitable but I would be nervous about how it will fail when it fails. You are putting something in your fuel tank that is not fuel!
I guess when I’m nearly a mile above terra firma I don’t want to take unnecessary chances. It’s different in your car, when you can pull over when your fuel line clogs and the engine dies.
Sorry I’m a Debbie Downer but poorer is a lot better than deader!
- Super User
- Away
21 Apr 2024 11:34 #10
by Super User
Replied by Super User on topic header tank leak
Sorry - only good advice available here.
Depending on the nature of the leak, a product called ProSeal is FAA approved for fuel lank repairs. I recommend you investigate it. There are several "flavors" so pick the right one for you. It is NOT a sloshing compound - stay away from those. It's a paint on product.
- Nathan Bissonette
21 Apr 2024 10:10 #11
by Nathan Bissonette
Replied by Nathan Bissonette on topic header tank leak
I hope I'm not violating the rules of this website, but I'm writing to ask for BAD advice. Let me explain:
Scroll down the posts to see the "Hardware Hank" repair some prior owner made to the header tank shutoff valve on my 415-C. The valve is wet and the cockpit smells like gas. Discoloration indicates the tank itself may be leaking.
I spoke with my AP and several Ercoupe owners. I received lots of GOOD advice. Pull the tank ($1,500) and replace it with one from Univair ($2,800) or have it rebuilt by Safe Skies Aviation in Ohio ($2,000) or drill out all the rivets myself, then clean, patch, reassemble ($??). Vern at Skyport does not have a servicable used one.
Okay, that's the Right way to fix it but there goes all the money I set aside for the Annual in June and my insurance in November. What's the Wrong way? How about trying to extend the tank life with PRC sloshing sealer - anybody had success with that? What other low-buck options are there?
If you don't want to comment on this website for fear of looking like a cheakskate in front of others, email me at This email address is being protected from spambots. You need JavaScript enabled to view it.. I really appreciate ALL the advice I get from this group. Thanks in advance.
- Nathan Bissonette
01 Apr 2024 15:30 #12
Ken, I found this on another website:
ercoupe.groups.io/g/Tech/topic/52666189?...0::,,,0,0,0,52666189
Does removing the header tank really involve that much work? I'm amazed you found somebody to do it for so little money. Who's your A/P? I'd like to get a quote on mine.
Time to create page: 0.169 seconds
