- Alon/M10 Specific
- Goodyear Nose wheel assembly 9532962 parts
- Martin Gibbs
18 Dec 2022 02:58 #7
by Martin Gibbs
Replied by Martin Gibbs on topic Goodyear Nose wheel assembly 9532962 parts
Hi Warren;
Thanks again for the great information.
I will continue searching and also give Vern a call.
Cheers;
Martin
Cheers;
Martin
- Martin Gibbs
18 Dec 2022 02:55 #8
by Martin Gibbs
Hi John;
Thanks for your feedback. I had the same results searching for used wheels. Ratty is a good summation. I checked the Parker-Cleveland catalog and they list the 40-17 as inactive.
Do you know if the rep from Parker considered the 40-77 to be a suitable replacement for the 40-17?
Thanks
Martin
Thanks
Martin
14 Dec 2022 22:49 #9
Replied by John Jones on topic Goodyear Nose wheel assembly 9532962 parts
40-17 is also listed for the Alons, note 205(d) in the TCDS along with the Goodyear.
14 Dec 2022 16:52 #10
Replied by Warren Hampton on topic Goodyear Nose wheel assembly 9532962 parts
40-17 is what is listed under Mooney M-10
14 Dec 2022 13:31 - 14 Dec 2022 13:35 #11
Martin, I looked up the felt I got from Aircraft Spruce #06-02872 It is hard to find the flat retainers the snap ring not so hard. The. Parker / Cleveland parts are priced way high for little parts. You mit call Vern to see what he has. I know he has a few Alons and an M10 down there at his salvage yard 803-360-2061 Good luck!
Last edit: 14 Dec 2022 13:35 by Warren Hampton. Reason: deleted parts
14 Dec 2022 10:53 #12
I have been searching for the same for the Cleveland wheel with no definitive results. I contacted Parker (manufacturer) if there was a substitute for the 40-17 and received this reply: "We spoke yesterday but I wanted to close the loop by saying the 40-77 is a 5.00-5 wheel and is close to the 40-17 wheel you asked about." I also check with Macfarlane about parts and they provided this chart. I also looked on ebay for both the Goodyear and Cleveland wheels and the only ones were what I would consider "ratty" at best. John
