- Control Yoke Mounting
- Shawn DUFFEE
02 Mar 2022 01:18 #7
by Shawn DUFFEE
Replied by Shawn DUFFEE on topic Control Yoke Mounting
I think I found it!
1995-3 Coupe Capers.
A blurb written by Melvin Shaffer on page 12. He shows a photo of the port I was hoping to make. No other details, but I think I can manage the rest.
Is this what you were thinking of, Ed?
- Shawn DUFFEE
28 Feb 2022 11:00 #8
by Shawn DUFFEE
Thanks for the tip Ed. I jave been scouring Capers. We have a 6hr flight home tomorrow and can read through some more. Finding all kinds of useful stuff in all these Caper files!
- Edward Taylor
23 Feb 2022 19:42 #9
by Edward Taylor
Replied by Edward Taylor on topic Control Yoke Mounting
Someone did an inspection cover on bottom of cabin for that reason a long time ago if I remember correctly. It was for just that reason and I think he received a field approval for it,
It was probably 20 years ago. Maybe someone remembers who, the write up was in Coupe Capers.
So does anyone else remember who? I will look through my old capers when it warms up in the hangar to try and find info.
Ed
Ed
- Shawn DUFFEE
21 Feb 2022 13:41 #10
by Shawn DUFFEE
Oh boy, and being 6'6" that sounds really fun.
I will contact our local DAR to see how difficult it would be.
I was actually planning on minimizing the cockpit interior so I may not even bother with things like the insulation. That's a bit down the road anyways....
21 Feb 2022 12:58 #11
Replied by Ronald Raty on topic Control Yoke Mounting
An access panel would be a good idea, because getting to the rod ends for the steering rod and the elevator rod are a real bear, requiring you to stand on your head and do everything by feel.
The blanket is 1946 technology. I replaced it with a stick on foam/foil soundproofing from Aircraft Spruce, on the theory that foil will dampen the high frequencies and the the foam will dampen the lower frequencies. I haven't noticed any real difference, the cockpit is still noisy. It would take a lot of effort to eliminate every noise leak.
- Shawn DUFFEE
21 Feb 2022 12:06 #12
by Shawn DUFFEE
Thanks Ron. I see now. And I see why Warren suggested a service plate there. What is there between the belly and the mast bottom - an inch or less?
Has anyone ever done a 337 for a port like that?
I see you have the sound insulation in the front. Is that still available, or is there an approved and improved version one would recommend?
Thank You!
Shawn
Thank You!
Shawn
