- Window Welt Glue
Window Welt Glue
- Randy Branson
21 Mar 2022 12:16 #1
by Randy Branson
Replied by Randy Branson on topic Window Welt Glue
Shawn,
BE PREPARED and FOREWARNED! Replacing the window welts is a royal pain in the ass. Even with Lynn's expert guidance and experience it still was a major pain. But it had to be done to protect the new windows I'd bought. Also, the last window welt job was jack-legged by someone.
- Randy Branson
21 Mar 2022 12:11 - 21 Mar 2022 12:17 #2
by Randy Branson
Lynn Nelsen and I replaced mine this past summer in my 'coupe. We used 3M 90 Hi Strength from Lowes. There are a couple of 3M types (77 and 90). Don't get the 77. It won't hold. The 3M 90 holds great, but takes at least 24 hours to fully cure. You will need a couple of cans to do the job.
Last edit: 21 Mar 2022 12:17 by Randy Branson.
06 Mar 2022 07:35 - 06 Mar 2022 07:36 #3
Replied by Larry Snyder on topic Window Welt Glue
That’s a real common mistake. The felt goes in the channel where the glue is, the windows slide in the vinyl.
Last edit: 06 Mar 2022 07:36 by Larry Snyder.
- Shawn DUFFEE
06 Mar 2022 00:28 #4
by Shawn DUFFEE
Replied by Shawn DUFFEE on topic Window Welt Glue
Thank you Larry.
I have not seen the pdf writeup before. I was surprised to see the sketch that shows the felt in the channel and not against the window.
The used one I have clearly was installed backward with the felt inside. I would have repeated the same thing.
05 Mar 2022 18:22 #5
- Shawn DUFFEE
05 Mar 2022 17:53 #6
by Shawn DUFFEE
Window Welt Glue was created by Shawn DUFFEE
Hello All,
I have seen some writeup about welt replacement, but have not seen any mention of which glue to use.
Can I assume it is contact cement? Or something else?
If contact cement, do both the welts and inside the track get coated, let dry a wee bit then squeeze in?
Thank you!
Shawn
Thank you!
Shawn
Time to create page: 0.135 seconds
