- Oil Tank Filler
Oil Tank Filler
- Tad Daughters
09 Jul 2022 20:20 #1
by Tad Daughters
Replied by Tad Daughters on topic Oil Tank Filler
My Forney F-1 with a C-90 has the oil filler on the starboard (right) side, having had the 4 quart tank replaced with a 6 quart model. The cowling has a filler door on the port (left) side of the cowling - no longer used... LOL! - so take your pick.
- Randy Branson
26 Jun 2022 13:36 #2
by Randy Branson
Replied by Randy Branson on topic Oil Tank Filler
My C85 is on the right. Yes, close to the exhaust stack, but not a problem except dribbles of oil get on it and you smell burnt oil afterwards. Not overly hot when doing enroute checks. BUT, it
would be more convent when doing checks if both it and gascolator were on the same side.
- Bruce Bennett
05 Jun 2022 17:29 #3
by Bruce Bennett
Replied by Bruce Bennett on topic Oil Tank Filler
My original C-75 had the filler on the left. I acquired another C-75 engine
and its filler is on the right. Having the filler on the left has easy access.
The right filler is by Cylinder 1 exhaust pipe making hot engine oil checks
uncomfortable..
uncomfortable..
27 May 2022 20:20 #4
Replied by Matt Gunsch on topic Oil Tank Filler
depends on the tank, the one on my C90 is on the left, I have another tank for a C90 and it is on the right.
27 May 2022 18:03 #5
Replied by Larry Snyder on topic Oil Tank Filler
My 415C with a C-75 has the oil filler on the left side. That engine is now a C-85. I’ve seen similar aircraft with the filler on the right side. I don’t know how they came from the factory.
- John Farrell
27 May 2022 17:46 #6
by John Farrell
Oil Tank Filler was created by John Farrell
Can the oil tank filler on a C-75 engine be either on the starboard or port side of the engine? My previous 415E with C-85 engine the oil filler was on the port side. I just looked at a 415 C with a C-75 engine and the filler oil cap was on the opposite (Starboard) side.
