- Remove big plug from carb
06 Jul 2022 09:19 #1
Replied by Ron Holmes on topic Remove big plug from carb
I didn't take any pictures of the screen but it was pretty clean...I sent a couple of pictures from inside the carb and the needle. I am trying to stop the carb from dripping when the fuel is turned on and the engine is not running. It is really a simple carb. My mixture control was wired shut and I am going to try to remedy the no mixture as well. There's a lot of safety wire on that thing.
- Robert James
05 Jul 2022 21:13 #2
by Robert James
Replied by Robert James on topic Remove big plug from carb
I’d be curious to know if you found anything in the screen behind the big plug? Cheers,
- Randy Branson
27 Jun 2022 12:37 #3
by Randy Branson
Replied by Randy Branson on topic Remove big plug from carb
Ah so. Thanks!
26 Jun 2022 16:17 #4
To check or clean the screen behind it...
- Randy Branson
26 Jun 2022 13:38 #5
by Randy Branson
I plead ignorance. Why did you need to remove the plug?
24 Jun 2022 19:30 #6
Got it off... better socket and a little PB Blaster and a better choice of tools... Bingo easy....
Time to create page: 0.101 seconds
