- Marvel-Shebler and fuel pump overhaul
30 Jul 2022 19:40 #7
Replied by Matt Gunsch on topic Marvel-Shebler and fuel pump overhaul
the C-90 has a engine driven fuel pump
- Paul Gilman
30 Jul 2022 16:12 #8
by Paul Gilman
Replied by Paul Gilman on topic Marvel-Shebler and fuel pump overhaul
Better mousetrap. I love the redundancy of the fuel pump and header tank combination.
Reacting to my earlier post ..I am thinking I will use my OEM fuel pump on my newly overhauled C-85. And I plan to use a 10-4240-01 Marvel-Shebler compliment with the STC for it's use.
Asking for comments fom others who have done this previously.
30 Jul 2022 10:31 #9
Replied by Larry Snyder on topic Marvel-Shebler and fuel pump overhaul
I don't think the C-90 has an option for a cam driven fuel pump, but I may be wrong. The ones I've seen had the electric pump. Since the pump on an Ercoupe does NOT feed the carburetor but just fills the cowl tank, it's not as critical as on other aircraft. I actually saw one 415C where the cowl tank was removed and it was plumbed with an electric pump to supply fuel from the wings directly to the carburetor. This plane had several off airport landings, and they could never maintain correct fuel pressure. They ended up reinstalling a cowl tank,
- Paul Gilman
29 Jul 2022 16:19 #10
by Paul Gilman
Thanks Larry. I looked at the AlphaAviation electric pump.
It is very likeable. Especially against a new $850 replacement pump.
By accident I have a friends Alon A2 aircoupe in my hanger. Looking at it the panel the Alon seems to have an electric fuel pump with a switch. I will have to ask my friend about it.
- Paul Gilman
29 Jul 2022 16:11 #11
by Paul Gilman
Ok..
The magneto's and harnesses were stock with the C-75 before the rebuild.
One had a rebuild and 500 hour inspection about 24 months ago.
The other is due. Both worked fine prior to the engine rebuild.
I will have to get you the dataplate information and logbook information.
I have your email.
Mine is This email address is being protected from spambots. You need JavaScript enabled to view it. in northern California
I have your email.
- Robert James
29 Jul 2022 12:20 #12
by Robert James
Replied by Robert James on topic Marvel-Shebler and fuel pump overhaul
If your going with new SlicK Mags, I could be interested in buying your old mags, but I’d need to know the info of the old mags data plates. If interested PM me at This email address is being protected from spambots. You need JavaScript enabled to view it.
Cheers,
Cheers,
Time to create page: 0.137 seconds
