- Fork, and inner cylinder stuck
06 Dec 2022 00:46 - 06 Dec 2022 00:48 #1
Replied by Warren Hampton on topic Fork, and inner cylinder stuck
Getting the fork off take heat. I heat-up the neck quickly and bump the fork off. it is best done by two people.
Last edit: 06 Dec 2022 00:48 by Warren Hampton. Reason: extra letter in a word
- Melvin Hall
05 Dec 2022 20:08 #2
by Melvin Hall
Replied by Melvin Hall on topic Fork, and inner cylinder stuck
Thank you Matt for the info you sent, that will come in handy as we replace necessary parts, also we were finally able to remove the whole assembly from the motor mount.
Again thanks for the info Matt.
05 Dec 2022 12:27 #3
Replied by Matt Gunsch on topic Fork, and inner cylinder stuck
It is not like a cessna, you have to pull the whole assembly out of the plane, here is how to take it apart
www.ercoupe.info/mobile/pmwiki.php/Main/OverhaulSteelStrut
- Melvin Hall
04 Dec 2022 19:52 #4
by Melvin Hall
Fork, and inner cylinder stuck was created by Melvin Hall
Time to create page: 0.184 seconds
