- Ramshorn yoke
Ramshorn yoke
- Ken Thompson
07 Apr 2023 15:42 #1
by Ken Thompson
Replied by Ken Thompson on topic Ramshorn yoke
I have the standard “pretzel” yoke. My push to talk button is a microswitch embedded in the yoke hub cover, easily operated with the thumb of your left hand without moving the hand on the yoke.
19 Mar 2023 01:21 - 19 Mar 2023 01:36 #2
Replied by Warren Hampton on topic Ramshorn yoke
All shafts are the same dia. Hole locations may diff. The hard part is getting the Erco wheel off... The C and CD shafts are the same length but with diff up stop hole locations. E and G with F1, F1A are longer. Alons are shorter M10 ?? 7/8" O.D
Last edit: 19 Mar 2023 01:36 by Warren Hampton. Reason: more to say
- David Gilson
09 Feb 2023 15:04 #3
by David Gilson
Replied by David Gilson on topic Ramshorn yoke
Thanks for the quick response. I was interested because they are "standard" yokes that I'm used to and a ptt switch can be easily mounted where a thumb can get to it. Currently the ptt is on the instrument panel.
09 Feb 2023 14:43 #4
Replied by Larry Snyder on topic Ramshorn yoke
If memory serves, they require a different size control shaft. It’s not a simple unbolt and swap. I like the looks of the pretzels. Plus they say “Ercoupe” at least if you have the right covers…
- David Gilson
09 Feb 2023 14:14 #5
by David Gilson
Ramshorn yoke was created by David Gilson
I'm considering installing ramshorn yokes on my 415c, is this a big production or just a few bolts. The paperwork included references cutting, this sounds a little offputting to me because once I cut something, I can't go back.
any info will be helpful..
thanks
thanks
Time to create page: 0.091 seconds
