- Mechanical fuel pumps for Ercoupe 415 85C
- David Gilson
10 May 2023 20:01 #1
by David Gilson
Replied by David Gilson on topic Mechanical fuel pumps for Ercoupe 415 85C
I'm gearing up for my annual in 3 months (first one on my watch) and looking at the then and now rebuild kits. Less than half the price of the partial kit at Aircraft spruce. Does the full kit contain all of the parts of the ass kit. It seems it's basically a cork gasket and a Fibre gasket. If anyone has bought the then and now kit, please enlighten me.
- Michael Hainen
14 Mar 2023 08:16 #2
by Michael Hainen
Replied by Michael Hainen on topic Mechanical fuel pumps for Ercoupe 415 85C
Just looked at the THEN & NOW site, good call if you know the maker and part number of your mechanical pump.
Also check out AIRCRAFT SPRUCE & SPECIALTY.
TEMPEST has a new to me line of overhauled to factory specs for old Continental engines.
www.aircraftspruce.com/catalog/pdf/TEMPEST-FP-APP-CON.pdf
11 Mar 2023 23:44 #3
Replied by Edward Moore on topic Mechanical fuel pumps for Ercoupe 415 85C
Check with Then and Now Automotive in Weymouth, MA, ,have a page.
They have a repair kit for these old pumps, may even offer a repair service.
Also, check the LINKs from here - Hartmut Beals info under fuel systems.
FWIW
FWIW
11 Mar 2023 16:33 #4
Replied by Larry Snyder on topic Mechanical fuel pumps for Ercoupe 415 85C
They are getting hard to find. Alpha Aviation sells a kit with STC to replace the mechanical pump with an electric one. The kit and STC are $600. You won’t find a mechanical pump for that amount. The STC includes an annunciator light on the panel that informs you when the wing tanks are dry.
The following user(s) said Thank You: Ron Holmes, Melvin Hall
- Melvin Hall
11 Mar 2023 16:21 #5
by Melvin Hall
Mechanical fuel pumps for Ercoupe 415 85C was created by Melvin Hall
Who sells new or rebuilt mechanical fuel pumps for Ercoupe 415 85C.
thanks
mh
thanks
mh
Time to create page: 0.133 seconds
