- Seat installation help
- Jerry Nograsek
29 May 2023 07:02 #1
by Jerry Nograsek
Replied by Jerry Nograsek on topic Seat installation help
Some pictures.
- Jerry Nograsek
29 May 2023 06:53 #2
by Jerry Nograsek
As Matt mentioned, on some, the seat back upholstery has the foam inserted in it, then the the seat back upholstery is laced around it circumference to the frame
28 May 2023 09:46 #3
Replied by Matt Gunsch on topic Seat installation help
the F-1 I work on has the same seat as my G model, the seat back is removable and is hinged at the bottom and held in place with 3 bolts or clevis pins. The earlier models the seat back is part of the airframe and seatback cushion is laced in place,
- Rob Payne
28 May 2023 02:06 #4
by Rob Payne
Seat installation help was created by Rob Payne
Hi i have a Forney F1 and live in Australia. When i purchased the aircraft it had C172 rear seats installed which weren't installed that well and i didn't like.
I purchased second hand seat frame and seat from Vern. There are not many Ercoupes in Australia so i can't look at another to verify the correct seat installation. And, what is the correct process for lacing up the back rest, before or after the frame install? And what foam is installed in the back rest the back rest currently doesn't have any foam installed. Any assistance with pics or articals would be appreciated.
Thanks Rob
Thanks Rob
Time to create page: 0.194 seconds
