- Ercoupe Airfilter
Ercoupe Airfilter
10 Oct 2023 18:49 - 10 Oct 2023 18:56 #1
Replied by Warren Hampton on topic Ercoupe Airfilter
When putting in the Bracket have a belt sander handy. Seems the frames are tight. of the 3 that I have installed I had to sand off some of the outside dia to fit. There three screws to hold the filter in place. May have to fight a little to get them together.
Last edit: 10 Oct 2023 18:56 by Warren Hampton. Reason: more to say
- Richard Sanders
03 Oct 2023 12:48 #2
by Richard Sanders
Replied by Richard Sanders on topic Ercoupe Airfilter
Did you have to remove the nose cowling to put the BRACKETT air filter?
- James Gouin
01 Jul 2023 12:19 #3
by James Gouin
Replied by James Gouin on topic Ercoupe Airfilter
Thanks Ron for the quick reply .
01 Jul 2023 11:42 - 01 Jul 2023 11:46 #4
Replied by Ronald Raty on topic Ercoupe Airfilter
I solved the problem by installing the Bracket air filter assembly, BA8810. Since you mention a foam filter, you may already have that, so need the Bracket air filter element, BA8805. I see that Univair sells both, as well as the older paper/metal encased filter which are hard to get in/out.
Last edit: 01 Jul 2023 11:46 by Ronald Raty.
- James Gouin
01 Jul 2023 07:36 #5
by James Gouin
Ercoupe Airfilter was created by James Gouin
The airfilter that univare sells iis to big for the hole , it's very tight . The old filter has 2 screens and the filter sponge in the middle . Any help would be appreciated.
Time to create page: 0.095 seconds
