- Ball not centered - no rudder pedals
- Ken Thompson
08 Dec 2023 16:18 #1
by Ken Thompson
Replied by Ken Thompson on topic Ball not centered - no rudder pedals
My very first thought was “check the gauge before messing with the rigging.” I’m a fan of checking the easiest and cheapest things first, before tearing into costly and time consuming projects.
Example: last year, my oil pressure was showing low. I posted and asked opinions. Several gave worst case scenarios including engine overhaul.
I stuck a $50 new gauge in there. Problem solved! (And yes, my work wS checked and signed off by my AP/IA.)
23 Oct 2023 18:32 #2
Replied by Warren Hampton on topic Ball not centered - no rudder pedals
Good, Love the pics of 00H! have not looked at logs yet. This last few weeks feeling poorly.
- RP J
23 Oct 2023 14:33 #3
by RP J
Replied by RP J on topic Ball not centered - no rudder pedals
This appears to have been the issue. When I checked the level between the two window sills and compare agains the ball, the ball was way off. The ball gauge is now adjusted so it is level with the window sills.
18 Oct 2023 17:46 #4
I was thinking about this last night. 3800H has a new panel put in and when it was drilled it may been drilled on a slight angle.
17 Oct 2023 21:39 #5
Replied by Matt Gunsch on topic Ball not centered - no rudder pedals
level the plane LT to RT, and see where the ball is, the mounting holes should be elongated to allow adjusting the instrument.
15 Oct 2023 19:12 #6
want to use an extra one I have my friend. I can ship it to you.
Time to create page: 0.185 seconds
