- Spark Plug Choices for C-90 12-F engine
- RP J
30 Dec 2023 00:56 #1
by RP J
Replied by RP J on topic Spark Plug Choices for C-90 12-F engine
A month old thread... but if you are still looking for plugs I recommend the Tempest BY plugs. You will have less fouling with this 'new' 50 year old design that was recently made available to us by Tempest.
www.aircraftspruce.com/catalog/eppages/temptestplugs8.php
The following user(s) said Thank You: Thomas Vorpe
- Keith Whitcomb
27 Nov 2023 10:10 #2
by Keith Whitcomb
Replied by Keith Whitcomb on topic Spark Plug Choices for C-90 12-F engine
cessna120140.com/wp-content/uploads/2019...Data-Sheet-E-252.pdf
Check the bottom of the last page for a detailed list of spark plugs.
- Thomas Vorpe
27 Nov 2023 08:19 #3
by Thomas Vorpe
Spark Plug Choices for C-90 12-F engine was created by Thomas Vorpe
Greetings All,
I am changing out my ignition leads and was hoping to use my current plugs which are in fine shape, however No one makes leads for the SL mags to mate to a plug with a 3/4 Barrel nut. So now I am hunting new plugs with the 5/8 barrel nut. I’ve looked in so many places for spark plugs approved for that engine and sometimes they list about 5 different part numbers from each manufacturer for the same engine. Not sure where I can find the last word on what spark plug should be in my engine. Even in the TCM type data specifications they have multiples of the same plug listed. Any help in any direction would be appreciated.
Thanks
Tom
Thanks
Tom
