- Fuel Syphoning
Fuel Syphoning
19 Jan 2024 00:25 - 19 Jan 2024 00:50 #7
Replied by Warren Hampton on topic Fuel Syphoning
Rereading of your question answered most of my thought's., other than gravity. Hard right pushes fuel left so the pump pulls from the right side the header tank overflow tube runs into the left Tant adding more fuel on top of the Fuel in the left Hence your overly filled tank...out it come out the vent.
Last edit: 19 Jan 2024 00:50 by Warren Hampton.
- Michael ODonnell
18 Jan 2024 20:53 #8
by Michael ODonnell
Replied by Michael ODonnell on topic Fuel Syphoning
Thank you for your suggestions. The header tank was not refueled and both wing tanks were at the same level (approximately 3 inches below the top of the tanks) after all of the maneuvering in attempts to diagnose.
18 Jan 2024 20:01 #9
Was the header tank filled after the mains? There is an overflow in the header tank, so you fill the header first....
- David Gilson
18 Jan 2024 18:54 #10
by David Gilson
Replied by David Gilson on topic Fuel Syphoning
Just a thought, maybe the self leveling fuel tube between the tanks is clogged/kinked and the fuel pump overflow in the header tank is doing its job and returning the fuel to one of the tanks, but then it's not self leveling between the wing tanks.
- Michael ODonnell
18 Jan 2024 14:01 #11
by Michael ODonnell
Fuel Syphoning was created by Michael ODonnell
I have an Ercoupe 415C that during the pre-buy exhibited fuel siphoning out of the left wing tank’s vent hole upon movement of the aircraft. A mechanic that was on the field removed two gallons of fuel, thinking that it was an overfill situation. The problem continued with ramp turns to the right having heavy flows and turns to the left no flow. Takeoff run demonstrated extreme amounts of fuel being discharge from the vent, flowing across the wing. The departure was aborted. Two mechanics examined the plane and are baffled. Switching the caps did not make a difference. Has anyone experienced such a problem and what could be a possible solution? Thanks, Mike
Time to create page: 0.369 seconds
