- I need Wing Installation and rebuilding the nose strut advice
- Keith Whitcomb
01 May 2024 13:10 #1
by Keith Whitcomb
Replied by Keith Whitcomb on topic I need Wing Installation and rebuilding the nose strut advice
I am an A&P in Georgia. If you have questions, you can call me @ 404-580-7008
- John Reed
01 May 2024 10:10 #2
by John Reed
Replied by John Reed on topic I need Wing Installation and rebuilding the nose strut advice
Can anyone recommend someone who can rebuild/overhaul a Ercoupe Model 415 forked nose gear strut - hopefully close to Livermore CA? It was rebult once before but still leaks so I would like a specialist to take a look at it.
John
John
- Keith Whitcomb
25 Apr 2024 20:54 #3
by Keith Whitcomb
call Vernon Greggory @ Skyport 803-360-2061. He sells new & used parts. He sells Univair parts/same prices as Univair.
He sold me everything to rebuild all 3 gear on my aircraft. The mains are pretty straightforward. He made sure I had everything and walked me through rebuilding the nose-gear.
The following user(s) said Thank You: John Reed
19 Apr 2024 12:30 #4
Replied by Larry Snyder on topic I need Wing Installation and rebuilding the nose strut advice
Looks like a pre war Ercoupe. I would contact Kevin English or Kevin Gassert, they are experts on low serial number Ercoupes. You can find them in the club registry in the FILES area of this site.
- John Reed
19 Apr 2024 12:25 #5
by John Reed
I need Wing Installation and rebuilding the nose strut advice was created by John Reed
I am an A&P/IA maintaining an Ercoupe 415-C S/N 215 here at the Livermore Airport California. The wings were removed to be rebuilt and soon I will have to install them. Do you have any advice about how I should proceed and the parts I need to attach them. Also, the nose strut is leaking and I will need to rebuild that. Any advice is appreciated.
John
John
