Winter oil temps
13 Nov 2019 15:54 #1 by Larry Snyder
Replied by Larry Snyder on topic Winter oil temps
There are plans for a plate to cover the oil sump cooling inlet right below the prop. I have it on my plane now, but it only increases oil temp 10-15 degrees. But every little bit helps. Skyport used to sell it as a kit. Maybe Vernon Gregory has them now. I don’t know where my drawings are, I made the plate many years ago.
  • Ken Thompson
13 Nov 2019 15:48 #2 by Ken Thompson
Winter oil temps was created by Ken Thompson
What should be the expected difference between oil temp and ambient temperature?
I’ve been showing about 140 oil temp with ambient aloft around 50-60F lately. Roughly, a 70-80 point spread.
I’ve heard 180 degrees is what you want but how do you do that in cold weather? If I get only 140 when the outside temp is 50, am I likely to get even less if the temp at altitude is really cold?
Do I need to duct tape the air intake?
