- How Elevate Ercoupe to Change Tires
- Victor Yordan
26 Aug 2021 15:48 #1
by Victor Yordan
Replied by Victor Yordan on topic How Elevate Ercoupe to Change Tires
I have some photos I can share but have not figured out how to attach them to this forum. I you are interested write me at This email address is being protected from spambots. You need JavaScript enabled to view it..
- Tim Cowden
20 Aug 2021 10:14 #2
by Tim Cowden
Replied by Tim Cowden on topic How to Elevate Ercoupe to Change Tires
Ken,
Thanks for your insight. My Ercoupe happens to be SN 670 so I will pursue the procedure you have detailed. Thanks again for your help.
Tim
Tim
- Kenneth Crofut
20 Aug 2021 07:49 #3
by Kenneth Crofut
Replied by Kenneth Crofut on topic How to Elevate Ercoupe to Change Tires
www.ercoupe.info/mobile/pmwiki.php/Main/Jacking.
If your 1946 is serial number 813 or above use the pipe thru knee joint and floor jack. If s/n 812 or lower you have to raise at wing tie downs. Above is link that explains how.
- Tim Cowden
19 Aug 2021 22:10 #4
by Tim Cowden
Thanks Ken,
So is the implication of your suggestion that the tie down points on the wings are strong points and that it is safe to put a jack there?
Tim
Tim
- Kenneth Crofut
17 Aug 2021 18:52 #5
by Kenneth Crofut
If the 1946C is serial number 812 or lower you must remove wing tie downs screw in bolt with washers and use aircraft jacks.
- Tim Cowden
12 Aug 2021 11:01 #6
by Tim Cowden
Thanks Matt.
Time to create page: 0.156 seconds
