- Max instrument depth on panel
30 Jun 2021 06:59 #1
Replied by Matt Gunsch on topic Max instrument depth on panel
Both my gyros were old and when I priced the cost of overhaul vs a AV-30, the AV was cheaper, plus I got rid of 13-16lbs of vacuum system.
- Chris Longfellow
29 Jun 2021 21:47 #2
by Chris Longfellow
Replied by Chris Longfellow on topic Max instrument depth on panel
appreciate the advice ... looks like the safe thing to do is a little exploratory look behind the panel
- Chris Longfellow
29 Jun 2021 21:45 #3
by Chris Longfellow
Thanks Matt, the AV-30 was the path I'm headed down. Before I pulled the trigger on that I wanted to take a quick look at others like the Garmin GI 275 ...just to make sure I don't have any regrets in the future.
Regardless I plan to relieve the airplane of the vacuum system.
29 Jun 2021 16:21 #4
Depending on what instruments you are overhauling, if it is a Attitude and DG, I would replace them with a AV-30 and remove the vacuum system.
The following user(s) said Thank You: Chris Longfellow
29 Jun 2021 12:06 #5
Replied by Ronald Raty on topic Max instrument depth on panel
You really just need to measure at the location you want to install the instrument. The header tank has overflow and supply tubes that get in the way, and don't forget to allow room for the connections of tubes and wires on the back of the instrument. If you try to extend under the tank, you start getting in the way of the control column. I found every instrument to be a custom fit, a lot of nesting.
- Chris Longfellow
29 Jun 2021 10:27 #6
by Chris Longfellow
Max instrument depth on panel was created by Chris Longfellow
Understand the header tank limits instruments to a depth of about 6" at the top of the panel. Where can I find the exact measurements (depth and how low on the panel the fuel tank extends). I'm looking to refurbish instruments but am unclear what exactly can fit.
Thanks in advance!
Thanks in advance!
Time to create page: 0.164 seconds
