- Belleville washer maintenance
01 Jan 2022 19:12 - 01 Jan 2022 19:17 #1
Replied by Warren Hampton on topic Belleville washer maintenance
That being said, The Belleville are pretty costly.The only hard thing on replacind donuts is getting the C CLIP out of the top housing of the shock... Some do not like the steel gear, I myself like them very much !
Last edit: 01 Jan 2022 19:17 by Warren Hampton.
- Keith Carden
01 Jan 2022 17:11 #2
by Keith Carden
Replied by Keith Carden on topic Belleville washer maintenance
Very helpful, thanks.
29 Dec 2021 13:31 #3
Find a set of steel Alon land gear and be done with all that mess!
- Keith Carden
28 Dec 2021 19:19 #4
by Keith Carden
Belleville washer maintenance was created by Keith Carden
I have a 46 coupe with the Bellville washer conversion on the main gear. Does anyone have info regarding the maintenance on this conversion?
I also have a 46 that I am restoring and that one has the original donut rings that are in need of replacement . Likely will just be sticking with the donuts on that gear but open to opinions on either set up.
thanks much
thanks much
Time to create page: 0.103 seconds
