- Why have a turn and bank?
- John Farrell
04 Jan 2024 22:04 #1
by John Farrell
Replied by John Farrell on topic Why have a turn and bank?
Pivotal Altitude. . . or illusive altitude!
04 Jan 2024 19:26 - 04 Jan 2024 19:32 #2
Replied by Warren Hampton on topic Why have a turn and bank?
Do you remember those 2 minute turns around a point? More bank down wind. Less bank upwind of the point... there was a name for that???
Last edit: 04 Jan 2024 19:32 by Warren Hampton. Reason: Adding more
04 Jan 2024 19:17 - 04 Jan 2024 19:30 #3
remember those 2-minute turns AROUND A POINT? ball and needle
Last edit: 04 Jan 2024 19:30 by Warren Hampton.
- Joseph Dezso
02 Jan 2024 19:56 #4
by Joseph Dezso
Replied by Joseph Dezso on topic Why have a turn and bank?
I assume you want to slip to lose altitude, just slow it down. Or to lose it really fast, with throttle at idle, hold the yoke all the way back against the stop, you will go down at about 900 fpm, when you have lost enough, release back pressure and add throttle. I suggest you practice this at altitude first.
- John Farrell
02 Jan 2024 19:16 #5
by John Farrell
At 60 degrees of bank, unless you add lots of power, you will need to hold significant back pressure on yoke to maintain altitude. And depending on engine, you may not have the extra power to maintain altitude. Furthermore, I believe 60 degrees of bank is considered an aerobatic maneuver. Personally I wouldn't be doing that in my 75 year old ERcoupe!
- Joseph Dezso
21 Dec 2023 15:26 #6
by Joseph Dezso
Which instruments are vacuum?
