- Fuel quanity
Fuel quanity
- Gale York
17 Dec 2019 06:13 #1
by Gale York
Replied by Gale York on topic Fuel quanity
Thanks Ronald. That’s exactly what I was afraid of, and needed to know.
16 Dec 2019 21:47 #2
Replied by Ronald Raty on topic Fuel quanity
AD 55-22-02
Unless the terneplate fuselage fuel tank has been replaced with a stainless steel tank and the terneplate wing fuel tanks replaced with aluminum alloy or stainless steel tanks, the tanks should be inspected frequently for signs of leakage at intervals not greater than 25 hours. If tank leakage is observed, the tank should be replaced with one of stainless steel or aluminum alloy, as required, before the next flight.
- Henry Pasquet
16 Dec 2019 16:11 #3
by Henry Pasquet
Replied by Henry Pasquet on topic Fuel quanity
Some had 5 gallon header tanks and 8 gallon wing tanks, for a total of 21 gallons.
- Gale York
16 Dec 2019 10:16 #4
by Gale York
Thanks for the reply. Do you know where to find detail on the early tanks; and pros/cons on steel?
16 Dec 2019 10:07 #5
Replied by Lawson Laslo on topic Fuel quanity
most have the 9-gallon wing tanks and 6 gallon header-=24 gal total
Earlier ones had 8-gallon wing tanks and 6 gallon header=22 gal total
the earlier ones were made out of steel I think it was later replaced with the 9-gallon tank.
- Gale York
15 Dec 2019 21:01 #6
by Gale York
Fuel quanity was created by Gale York
I’m looking at a ‘46/415-D, and see 21 gallons instead of 24 gallons. I also understand some earlier C’s had 2! Gal
Capacity. Would like a bit more understanding for this, and wonder where the 3 gal. Went?
Gale York
Gale York
Time to create page: 0.114 seconds
