- Artificial horizon and VSI not working.
- 10109
23 Jan 2016 19:46 #1
by 10109
Replied by 10109 on topic Artificial horizon and VSI not working.
Thanks to 9994. I think you hit the problem. I'll check it out. Regards, Larry
23 Jan 2016 13:57 #2
Replied by Ronald Raty on topic Artificial horizon and VSI not working.
I don't think the two systems share any components. The VSI runs off the pitot pressure, the AH runs off a vacuum. However, if the hoses for the two got inadvertently switched, there would now be pressure where there should be vaccum and vice versa. It might make those gauges reversed.
The following user(s) said Thank You: 10109
21 Jan 2016 14:29 #3
Replied by Larry Snyder on topic Artificial horizon and VSI not working.
I'm not much help here, but I would have someone who knows check the air tubing out in your plane. VSI could just be a line connected to the wrong place, and artificial horizons are gyro instruments and it could be just plain not working. I assume you have a venturi driving the artificial horizon, perhaps there's a kink in the air line between them...
Larry
N99340
Larry
N99340
- Brandon Brooks
13 Jan 2016 15:08 #4
by Brandon Brooks
Replied by Brandon Brooks on topic Artificial horizon and VSI not working.
You're not by any chance flying inverted are you? That might explain it.
- 10109
23 Oct 2015 00:07 #5
by 10109
Artificial horizon and VSI not working. was created by 10109
My Ercoupe 415C is wonderful except for one problem and I don't know what to look for. When flying my artificial horizon will turn upside down and my VSI (vertical speed indicator) reads backwards. When I go up it reads going down and so on. Because they are happening together I'm wondering if they have a common cause. I'm not sure what to look for. Even if I can't fix it myself, I like to know the cause so some mechanic can't nail me to the wall. Thanks for any help you can give me. The plane does have a venturi on the left side. Regards, Larry N93436
