- Which engine Preheater
19 Nov 2015 19:49 - 19 Nov 2015 19:50 #1
Replied by Larry Snyder on topic Which engine Preheater
I have the Aerotherm original heater. It has a unit that hangs on the prop and has two large ducts, one going into each engine cooling intakes. Lots of foam rubber to seal around the openings. It pulls air from one side of the engine, heats it, and blows it into the other side. By recirculating the air from the engine compartment, it is more efficient. It is thermostatically controlled, so you can hook it up and leave it, and the plane will be ready for you whenever you need to fly. The main problem is taking it with you, it's rather large, and finding a place to plug it in at your destination. We tend to take trips and there needs to be a way to preheat at our destination. It's too big if we are bringing any baggage with us. But it's the best way to preheat, since it warms the entire engine compartment.
Larry
N99340
Larry
N99340
Last edit: 19 Nov 2015 19:50 by Larry Snyder.
- Cathy Boyko
19 Nov 2015 06:42 #2
by Cathy Boyko
Replied by Cathy Boyko on topic Which engine Preheater
I have a device which bolts under the oil pan and has a series of elements which heat up. This was from another aircraft (my mechanic had it) so I do not know the name or if they are still available. I also block the holes in the cowl and throw some blankets "over the hood" to help keep the heat in.
The problems with this design are several. First, it only heats the oil, so it does not address the issue of "tightness" of components higher up in the block. It would provide some warmth up higher I suppose if left plugged in for an extended period. Also, there are "diapers" that you can strap on the oil pan to keep the oil from cooling during flight. I cannot use these with my heater...the diaper will get oil on it and would present a fire risk.
I have seen others use a ceramic brick heater rigged up to blow warm air into the engine bay. Sort of a mini Herman Nelson heater. This would be better to heat the metal in the block, but I don't feel comfortable leaving a rig like that unattended.
The other thing to consider is oil temp in flight. This is my biggest problem as I have the Kenney fibreglass nosebowl and no blockoff plates for it. So my oil won't stay warm enough at my usual altitudes when ground temps dip below -5*C. It just air cools too effectively. And truthfully, MY old frame gets a bit chilly below that anyway. I use a sheepskin over my lap and a stuffed toy or two to block any drafts. Always dress as though you will be stuck in the plane after an unexpected off field landing. It would suck to survive an incident and then get frostbite (or worse).
Winter does offer beautiful still air and clear crisp sunshine, so it is well worth the effort. Just beware of warm fronts, they are evil in the cold months. I get to enjoy lake effect and skating rink landing strips, but at least they state the friction index here. Curling stones are best left in the rink...not something I want to become in my coupe!
Cathy, crazy Coupe chick from the banana belt of Canada (Niagara)
- Cathy Boyko
19 Nov 2015 06:36 - 19 Nov 2015 06:48 #3
by Cathy Boyko
sorry duplicate post
Last edit: 19 Nov 2015 06:48 by Cathy Boyko. Reason: duplicate post
- 10207
11 Nov 2015 08:00 #4
by 10207
Which engine Preheater was created by 10207
I am going to buy an engine preheater. I am wondering what the opinion is of the group is for which is the best. I plan to fly into small northern Minnesota airports that have no FBO to do things like go ice fishing with my friend who lives up there. The airports typically have an electrical plugin that you can use. My friend will let me use an extension cord so I will not need to bring one with . Someday I might even buy a little Honda generator that I could bring with. My coupe is a 1947 415CD with a C-85. FYI The further north you live the more credibility will radiate from your words of wisdom. =|;o)
Time to create page: 0.104 seconds
