- Remnove slop from the control yoke
20 May 2022 16:33 #1
Replied by Larry Snyder on topic Remnove slop from the control yoke
ercoupe.org/tiny/e
You will be prompted for your EOC login credentials, then you can download the .mp4 file.
- Thomas Ryan
20 May 2022 16:28 #2
by Thomas Ryan
Replied by Thomas Ryan on topic Remnove slop from the control yoke
didn't see where the video was?
20 May 2022 11:46 #3
Replied by John Jones on topic Remnove slop from the control yoke
Also check the Jan 21 Coupe Capers and the video listed just above it.
20 May 2022 11:33 #4
Replied by Matt Gunsch on topic Remnove slop from the control yoke
The best fix, is of course the one that corrects the problem, and that can take some time to trouble shoot. Start at the nose and work your way aft. Put a tow bar on the nose and turn it and see how much slop there is, Check the rod ends on the steering rod, check the nose wheel bearings and tire pressure, Where the steering collar attaches to the nose gear there are peel ply shims, are they worn out ?
- Thomas Ryan
20 May 2022 03:46 #5
by Thomas Ryan
It has no rudder pedals, I steer with the control yoke, and the yoke supplies the elevator, aileron and rudder control. I sense too much play in the control yoke and the nose wheel shimmy i assume is a worn bearing or ? Question is "what is the best fix?"
19 May 2022 18:35 #6
Do you steer with rudder pedals or the control yoke (conventional 3 axis control or the optional 2 axis "coordinated" control)?
